ATTDIA system variable
Attribute dialog
Specifies whether or not the INSERT command uses a dialog box for entering attribute values.
| Type: |
Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: |
Off (0): Don’t use dialog box On (1): Use dialog box |
