account
translation
Bricsys Help Center
  2. Referência de variáveis do sistema/
  3. A/
  4. ATTDIA variável de sistema/
ANTIALIASSCREEN variável de sistema
APBOX variável de sistema
APERTURE variável de sistema
AREAPREC variável de sistema
AREAUNITS variável de sistema
AREA variável de sistema
ARRAYASSOCIATIVITY variável de sistema
ARRAYEDITSTATE variável de sistema
ARRAYTYPE variável de sistema
ATTFULLUPDATE variável de sistema
ATTMODE variável de sistema
ATTRACTIONDISTANCE variável de sistema
On this page
Attribute dialog
Related commands
  • INSERT command
  • -INSERT command
Related information
  • Defining attributes
  • Inserting blocks
  • Inserting blocks with attributes
  • Working with attributes
ATTDIA system variable
Attribute dialog
Shows a dialog box for attribute values for the INSERT command.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t use dialog box
On (1): Use dialog box
Related commands
  • INSERT command
  • -INSERT command
Related information
  • Inserting blocks
Products
BricsCAD® LiteBricsCAD® ProBricsCAD® BIMBricsCAD® MechanicalBricsCAD® UltimateCommunicator for BricsCAD®Bricsys® 24/7BricsCAD® ShapeApplication Catalog
Learn & Support
Product documentationForumBlogKnowledge baseWebinarsLearningDeveloper documentationRelease NotesContact support
About
About BricsysBecome a resellerCustomer StoriesAutoCAD® AlternativeEventsNewsroom
Buy
Store BricsCADStore 24/7MaintenanceFind a resellerStudents and Schools
My Account
My AccountManage LicensesMy support requestsInvoices and payments
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
ATTDIA system variable - BricsCAD Lite & Pro | Bricsys Help Center
