ATTFULLUPDATE system variable
Reset attributes after editing the block record
If on, the attributes in the associated block references are synchronized.
That is, their parameters, such as rotation angle, position, height of the font, etc. (except the text values), are set in accordance with those of the attribute definitions. Additionally, the missing attributes are restored, and those that have no definitions are removed.
If off, nothing is done.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Nothing is done.
On (1): The attributes in the associated block references are synchronized.
