ATTFULLUPDATE system variable
Reset attributes when editing a block parameter
Adjusts the behavior of parametric blocks' attributes.
If on, when changing a parameter of a block reference causes the underlying block to be cloned, the values of all attributes of the block reference will be reset to the values in the original block.
If off, only the missing attributes will be copied from the original block.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: | Off (0): Only the missing attributes will be copied from the original block. On (1): The values of all attributes of the block reference will be reset to the values in the original block. |
