ATTMODE system variable
Attribute display mode
Controls the display of attributes.
Note: If the ATTMODE variable is set to 2, all attributes display, including Hidden attributes.
Type:
Short
Saved in:
Drawing
Default value:
1
Possible values:
0: Don't show
1: As defined in block
2: Show all
Related commands
  • ATTDEF command
  • -ATTDEF command
  • EATTEDIT command
Related information
  • Working with attributes
