AUDITCTL system variable
Audit control
Creates an audit report (ADT) file when the AUDIT command is used.
When you turn on the AUDITCTL settings variable, AUDIT creates an ASCII file describing problems and the action taken. This report, with the file extension ADT, is placed in the same directory as the current drawing.
| Type: |
Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: |
Off (0): Don’t write ADT files On (1): Write ADT files |
