AUTOCOMPLETEMODE system variable
Auto complete mode
Controls the types features shown at the Command line.
Type:
Short
Saved in:
Registry
Range:
0 to 127
Default value:
47
Possible values:
1: Enable
2: Auto-Append
4: Suggestion List
8: Display Icons (unsupported)
16: Exclude the display of System Variables
32: Display preference variables
64: Enable Auto-Correction
Note:
  • Bit flag 1 must be turned on for any of the other flags to function.
  • Bit flag 4 toggles the display of the suggestion list in the Command line. For the 16, 32 or 64 bit flags to function in the Command line suggestion list, bit flag 4 must be turned on.
  • If DYNPROMPT is On, bit flags 16, 32 or 64 also affect the display in the dynamic input tooltip.
