AUTOMATICSTAIRSECTIONBEHAVIOR system variable
Automatic stair section behavior
Controls the generation of 2D representations of BIM stair entities during a section generation.
Affects only the automatic stair sectioning behavior. See the BIMGENERATE2DSTAIR command.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Default value: |
0 |
| Possible values: |
0: Symbolic 1: Geometric |
If set to Symbolic, a symbolic representation of entities classified as Stairs will be generated during section generation. This will affect only the automatic stair sectioning behavior. To customize, launch the BIMGENERATE2DSTAIR command before sectioning.
