AUTOMATICSTAIRSECTIONBEHAVIOR system variable
Automatic stair section behavior
Controls the generation of 2D representations of BIM stair entities during a section generation.
Affects only the automatic stair sectioning behavior. See the BIMGENERATE2DSTAIR command.
BricsCAD only
Type:
Short
Saved in:
Registry
Default value:
0
Possible values:
0: Symbolic
1: Geometric
If set to Symbolic, a symbolic representation of entities classified as Stairs will be generated during section generation. This will affect only the automatic stair sectioning behavior. To customize, launch the BIMGENERATE2DSTAIR command before sectioning.
