AUTOMATICTEES system variable
Automatic tees
Controls automatic creation of the tee flow fitting in case of T type connection in the BIMFLOWCONNECT command.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
| Possible values: |
Off (0): Disable On (1): Enable |
