BATCHEDBLOCKS system variable
Batched Blocks
Batched blocks will batch geometry in blocks for visualization if possible.
This is a background detail and should only have effect on performance.
Reopening the current drawing might be required for the batching to take effect.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: Disable batched blocks 1: Enable batched blocks |
Note: When the BATCHEDBLOCKS system variable is On, performance improves.
