BEDITASSOCMODE system variable
Associative identifiers in BEDIT
Controls if additional service data is generated during the BEDIT command.
This enables the automatic re-association of constraints and dimensions attached to the references of the block, including references in other documents.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
1 |
| Possible values: |
0: Do not initialize identifiers in BEDIT 1: Initialize identifiers in BEDIT |
