BIMDEFAULTPROPERTIESPATH system variable
Default properties path
The file paths for properties, loaded when a new document is opened.
BricsCAD only
| Type: |
String |
| Saved in: |
Registry |
| Default value: | bimproj_user.xml;bimproj_IFC.xml;bimproj_quantity.xml |
