BINDTYPE system variable
Xref bind type
Controls how XRefs names are handled when XRefs are bound or edited in place.
If on, uses insert-like behavior. If off, uses traditional bind behavior.
| Type: |
Boolean |
| Saved in: |
Not saved |
| Default value: |
0 |
| Possible values: |
Off (0): Traditional binding behavior On (1): Insert-like behavior |
- If the BINDTYPE system variable = 1 (Insert-like behavior): Xrefs will be converted into blocks.
- If BINDTYPE system variable = 0 (Traditional binding behavior): it binds the xref and makes the xref part of the drawing (the objects/layers from the external drawing will be added to the current drawing with the prefix equal to the file name).
