BKGCOLORPBEDIT system variable
Background color in the Parametric Block Editor
Controls the background color of the drawing window in the Parametric Block Editor.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
RGB:163,163,163
Related commands
  • BACKGROUND command
  • BEDIT command
  • BESETTINGS command
Related variables
  • BKGCOLOR system variable
  • BKGCOLORDBEDIT system variable
Related information
  • Dynamic blocks
  • Overview of background settings
Octave
