BLIPMODE system variable
Blip mode
Toggles the display of blips that are made as you pick points in the drawing.
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: | Off (0): Don’t display marker blips On (1): Display marker blips |
