BLOCKIFYMODE system variable
Blockify settings
Controls the behavior of the BLOCKIFY and PARAMETRICBLOCKIFY commands.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
16 to 247 |
| Default value: |
176 |
| Possible options: |
1: Use entire drawing as search space 2: Use default block insertion point 4: Use default block name 32: Compare geometry only 64: Convert unique solids to blocks 128: Show preview |
