BLOCKIFYMODE system variable
Blockify settings
Controls the behavior of the BLOCKIFY command.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 871
Default value:
71
Possible options:
1: Use entire drawing as search space
2: Use default block insertion point
4: Use default block name
32: Compare geometry only
64: Convert unique solids
256: Use parameters and constraints
512: Prevent loss of parametrics
