BLOCKIFYSCANNER system variable
Blockify scanner
Enables or disables the display of blockify suggestions in the block dialog. When enabled, the dialog will show suggestions for similar blocks.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
Off |
| Possible values: |
Off (0): Don’t run background blockify On (1): Run background blockify |
