BLOCKIFYTOLERANCE system variable
Blockify tolerance
Controls the relative tolerance used in the BLOCKIFY command to determine if two entities are equal.
A negative value means the program will determine the optimal tolerance (recommended).
BricsCAD only
| Type: |
Real |
| Saved in: |
Registry |
| Default value: |
-1.0 |
