BLOCKTESTWINDOW system variable
Block test window (Read Only)
This system variable is set to 1 if the test block window is current.
| Type: |
Boolean |
| Saved in: |
Not saved |
| Range: |
0 to 1 |
| Default value: |
0 |
| Possible values: |
0: The test block window is not current 1: The test block window is current |
