BMTOOLPATH system variable
Assembly Inspect tool search paths
The file paths used for searching tool files in Assembly Inspect.
Separate file paths with semicolons (;). If left empty, it defaults to the installed Design library Tools folder.
BricsCAD only
| Type: |
String Standard |
| Saved in: |
Registry |
| Default value: |
C:\Program Files\Bricsys\BricsCAD V26 en_US\UserDataCache\Support\en_US\DesignLibrary\Tools\ |
