BOLTINGASMDEFAULTLENGTHINCREMENT system variable
Default length increment
Controls the default length increment for the default stud, see the BOLTINGASMDEFAULTSTUD system variable.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Default value: |
25.4 |
Note:
- If INSUNITS=inches (1), the default value of BOLTINGASMDEFAULTLENGTHINCREMENT is 1.0.
- If INSUNITS=millimeters (4), the default value of BOLTINGASMDEFAULTLENGTHINCREMENT is 25.4.
