BOLTINGASMDEFAULTNUT system variable
Default nut
Controls the default nut used to generate bolt assemblies.
BricsCAD only
| Type: |
String |
| Saved in: |
Drawing |
| Default value: |
ASME B18.2.2 Heavy Hex Nut |
BricsCAD only
| Type: |
String |
| Saved in: |
Drawing |
| Default value: |
