BOMPROPERTYSET system variable
Default BOM property set
Sets the default set of properties for BOM tables.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
1 to 3
Default value:
1
Possible options:
1: Mechanical-only properties
2: All properties except coordinates
3: All properties
Note: If the BOM filter mode requires to include non-mechanical objects (BOMFILTERSETTINGS = 2 / 4 / 6)), then the property set will be automatically extended to include all properties except coordinates (BOMPROPERTYSET=2).
