BOMTEMPLATE system variable
Default template
Controls the file path for the default BOM template.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
Related commands
  • BMBALLOON command
  • BMBOM command
  • BMBOMEDIT command
  • -BMBOMEXPORT command
  • BMBOMEXPORT command
  • BMBOMPANELOPEN command
  • BMBOMTEMPLATEEDIT command
Related information
  • Templates
