BPTEXTHORIZONTAL system variable
Parameter Text Alignment
Forces the text displayed for action parameters and constraint parameters in the Block Editor to be horizontal.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Does not force the text for action parameters and constraint parameters in the Block Editor to display horizontally. On (1): Displays the text for action parameters and constraint parameters in the Block Editor horizontally. |
