CETRANSPARENCY system variable
Transparency
Sets the transparency for new entities.
| Type: |
String |
| Saved in: |
Drawing |
| Default value: | ByLayer |
| Possible options: |
ByLayer: Apply the layer’s transparency ByBlock: Apply the block’s transparency 0: Apply no transparency (fully opaque) 1-90: Apply transparency percentage from least (1) to most (90) transparent |
