CHECKDWLPRESENCE system variable
Check DWL file existence before open
Warn if there is a DWL lock file when a drawing is opened, indicates that another user has the drawing open.
The content of the lock files allows to inform other users trying to open that drawing, that it is in use, since when, and by whom. This is typically useful for drawings on a shared folder that can be accessed by multiple users from different operating systems.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off (Windows) On (Mac & Linux) |
| Possible values: | Off (0): Don’t check DWL file existence before opening a drawing On (1): Check DWL file existence before opening a drawing |
