CLEANSCREENSTATE system variable
Clean screen state (Read Only)
Indicates if clean screen state is active. Use the CLEANSCREENON and CLEANSCREENOFF commands.
Activating the clean screen state makes the drawing area larger by hiding elements of the user interface.
| Type: |
Boolean |
| Saved in: |
Not saved |
| Default value: |
Off |
