CLOUDUPLOADDEPENDENCIES system variable
Cloud upload dependencies
Specifies what to do with dependencies (such as external references or images) when a drawing is uploaded to Bricsys 24/7.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 2 |
| Default value: |
1 |
| Possible values: |
0: Upload drawing only (ignore dependencies) 1: Use eTransmit dialog if the drawing contains external references 2: Always use eTransmit dialog |
