CMDACTIVE system variable
Active command (Read Only)
Indicates the type of the current command.
| Type: |
Short |
| Saved in: |
Not saved |
| Default value: |
1 |
| Possible options: |
1: Ordinary command is active 2: Ordinary command and a transparent command are active 4: Script is active 8: Dialog box is active 16: DDE is active 32: lisp is active (only visible to an ObjectARX-defined command) 64: ObjectARX command is active |
