CMDLINEEDITFGCOLOR system variable
Command line edit foreground color
The Command line edit field foreground color.
Color may be represented as a name (for standard colors) or as RGB values. At the Command line, color may be entered as a name (for standard colors), RGB values, or HTML color.
BricsCAD only
Type: | String |
Saved in: | Preference |
Default value: |
White (Settings dialog) #FFFFFF (Command line) |
