CMDLINEFADINGLOGBGCOLOR system variable
Command line fade log background color
The Command line fade log background color.
Color may be represented as a name (for standard colors) or as RGB values. At the Command line, color may be entered as a name (for standard colors), RGB values, or HTML color.
BricsCAD only
Type:
String
Saved in:
Preference
Default value:
RGB: 50 54 56 (Settings dialog)
#323638 (Command line)
