CMDLINEFRAMEACTIVETRANSPARENCY system variable
Command line frame transparency when active
Controls Command line frame transparency when active. Values between 0 and 100 are accepted.
A value of zero means fully opaque, 100 if fully transparent.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 100 |
Default value: |
10 |
