CMDLINEFRAMEINACTIVETRANSPARENCY system variable
Command line frame transparency when inactive
Controls the Command line frame transparency when inactive.
Values between 0 and 100 are accepted. A value of zero means fully opaque, 100 is fully transparent.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 100 |
| Default value: |
30 |
