CMDLINEFRAMEUSETEXTSCR system variable
Command line frame TEXTSCR
When the Command line is floating, controls the effect of TEXTSCR command, also impacts log prompt delay. If on, displays a separate window, the same as in the docked state. If off, displays as a mini-frame.
BricsCAD only
| Type: |
 Boolean  |
| Saved in: |
 Preference  |
| Default value: |
 On  |
| Possible values: |
 Off (0): Don’t display (TEXTSCR) history window in a separate floating frame On (1): Display (TEXTSCR) history window in a separate floating frame  |
