CMDLINEUSEMINIFRAME system variable
Command line mini floating frame
Controls if the mini-frame is used when the Command line floats.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Don’t use new mini-frame On (1): Use new mini-frame |
Note: The CMDLINEUSEMINIFRAME system variable replaces the CMDLINEUSENEWFRAME system variable.
