CMDLINEUSENEWFRAME system variable
Command line use new floating frame (Windows)
Specifies whether the new mini-frame is used when the Command line is floating.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Don’t use new mini-frame On (1): Use new mini-frame |
