CMLSCALE system variable
Multiline scale
Controls the overall distance between lines created with the MLINE command.
A negative value mirrors the offset lines.
Type:
Real
Saved in:
Drawing
Default value:
1.0
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 20.0.
