CMLSCALE system variable
Multiline scale
Controls the overall distance between lines created with the MLINE command.
A negative value mirrors the offset lines.
Type:
Real
Saved in:
Drawing
Default value:
1.0: If MEASUREMENT=0 and INSUNITS=inches
20.0: If MEASUREMENT=1 and INSUNITS=millimeters
Related commands
  • MLINE command
Related variables
  • MEASUREMENT system variable
  • INSUNITS system variable
