CMPFADECTL system variable
Fade - DWGCOMPARE
Controls the fade level for unmodified entities during the DWGCOMPARE command.
Values between 0 and 90 are accepted. A value of zero means Maximum opacity, 90 means maximum transparency.
BricsCAD only
Type: |
Short |
Saved in: |
Registry |
Range: |
0 to 90 |
Default value: |
80 |
