COMACADCOMPATIBILITY system variable
COM Acad compatibility
Use registry settings to make existing VB applications run with BricsCAD.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | Off |
| Possible values: |
Off (0): Don’t use registry settings On (1): Use registry settings |
Note: When the COMACADCOMPATIBILITY system variable is set to On, AutoCAD® drawing files that are embedded as OLE objects in other applications will open in BricsCAD.
