COMMUNICATORBACKGROUNDMODE system variable
Perform import and export in background
Enables user interaction while import/export is performed.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Disable the import and export in background On (1): Enable the import and export in background |
