COMMUNICATORBACKGROUNDMODE system variable
Perform import and export in background
Enables user interaction while import or export is performed.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Disables user interaction while import or export is performed. On (1): Enables user interaction while import or export is performed. |
