COMPONENTSPATH system variable
Library directory path
The file path(s) for user created components.
Separate file paths with semicolons (;).
BricsCAD only
Type:
String
Saved in:
Registry
Related commands
  • BLOCKIFY command
  • -CREATELIBRARYBLOCK command
