COMPONENTSPATH system variable
Library directory path
Specifies the folder(s) in which BricsCAD should look for user created library files.
BricsCAD only
Type: | String |
Saved in: | Registry |
COMPONENTSPATH system variable - BricsCAD Lite & Pro | Bricsys Help Center
