COPYGUIDED3DDISPLAYSOURCEFACES system variable
COPYGUIDED3D source faces
Displays source faces during the COPYGUIDED3D command. Source faces are used to position the copied entity/entities.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Disable display of source faces On (1): Enable display of source faces |
