CPLOTSTYLE system variable
Current plot style
Controls the plot style for new entities. In color-dependent mode drawings this is "BYCOLOR" and is read-only. In named-plot-style mode drawings, the options: "BYLAYER" (default), "BYBLOCK", "NORMAL" and "USER DEFINED", this can be changed. See also the PSTYLEMODE system variable. Use the CONVERTPSTYLES command to convert the current drawing to use named or color-dependent plot styles.
Note: To convert the current drawing to use named or color-dependent plot styles, use CONVERTPSTYLES.
| Type: | String |
| Saved in: | Drawing |
