CVANGLESAMPLINGINTERVAL system variable
Angle sampling interval
Controls the angle sampling interval in decimal degrees, used to round gradings at convex vertices.
BricsCAD only
Type:
Real
Saved in:
Drawing
Range:
0 to 90
Default value: 5
Related commands
  • GRADING command
  • GRADINGBALANCE command
  • GRADINGEDIT command
